Worked on getting wing fairings in place. Both sides are clecoed in place and ready to drill out to final A4 size. I will use an A4 rivet with a washer on the head part to distribute load on the fairing so rivet does not crack or pull thru fiberglass. Took some work with my heat gun to get fairings to fit especially as they approach the rear of the aircraft where the flaps are located. I will also need to do some more heat gun work to get fairings to lay flat on flaps. Overall I am pleased with the results and it will look much better than the black rubber strip as well as make the plane much aerodynamic.
