Spaced out nutplates on access door opening and drilled holes for nutplates. Countersunk rivet holes for A3 rivets. Also drilled 7/32" holes in door. Riveted nutplates in place. Will leave door off while other work is being completed and will installed when have interior rear fuselage mostly complete. Also tried out some clip nuts for holding the center console together. With some minor modificatons to the clip nuts, I think they will work just about as good as nutplates and will be much easier to install.
