Brief Description: Install Lower nose gear support bracket
Got nose wheel parts from Zenith and started working on installation. Drilled, deburred and bolted loxer gear bearing support to fuselage. I put the lower gear bearing on support bracket and then inserted nose gear. Unfortunately the base plate on the botton of the gear was not aligned with the steering tabs so when the steering tabs where in the centering groove of the lower bearing the base plate was off center by about 3 degrees. Roger at Zenith is sending me another nose gear. Will move on to other small parts until nose gear arrives.
