Larrys Web Site
Date:  2-23-2017
Manual Reference:  6B
Brief Description:  Set rudder cable tension
Decided to work on setting rudder cable tension. Slowly adjusted rudder turnbuckles until rudder was centered and cable tension was 22# +/- 5#. I used a Burrroughs Cable tension gage to check cable tension. The tension in these pictures is reading about 27#s. I figured the cable will stretch some initially. I will check it again in a couple of weeks. Then I will safety wire the turnbuckles.
Left rudder cable tension
Right rudder cable tension
