Brief Description: Getting rudder fixed to neutral position
Used my vertical laser level to align rudder with center line of aircraft. That part was fairly easy once I got everything in position. I need to get rudder in neutral position so I can attach rudder cables to pedals. I was strmped on how to hold redder in neutral position while I pulled on rudder cables but after some serious deep thinking I came up with the idea of just clecoing a bracket from the rudder to the fuselage. And it actually worked!! Now I can pull the cables tight and get them clamped and swaged without too much trouble.
