Put lower cowling back on plane and marked exhaust pipe hole. Cut out hole and tested fit. Looks very nice! Also painted inside of lower cowlinjg with one coat of epoxy primer and two coats of high temperature engine enamel paint. This should help in seeing/finding any leaks and it will also prevent leaks from seeping into fiberglass.
