Larrys Web Site
Date:  11-30-2017
Number of Hours:  4.00
Brief Description:  Instrument panel work
Made more cutouts in the paper for the USB extensio, the flap switch and the throttle. Connected wires to flap switch and installed in panel. Installed USB extension and plugged cables into Dynon display. Drilled hole in firewall for throttle. Installed grommet and and ran throttle cable from panel to engine. Still need to tie down throttle cable on front siide of firewall.
Panel gets morer stuff
Back side of flap switch
Throttle cable thru firewall
