Brief Description: Install fire extinguisher and misc items
Worked on numerous misc items today. First I rivetted the cover plates on the aileron trim and on the elevator trim. Next I measured the arm distance to all wheels for weight and balance calculations. I still need to weigh aircraft. Then I mounted the top cover on the center console. I hinged the rear and used screws with screw plates to attach top to side panels. This will allow me to open up the top cover and do any work that might need to be done inside the center console. Also use heavy duty carpet tape to install carpet in baggage area and at both seats on the floor where your feet rest.
