Drilled A4 holes in fairings for rivets. Used a washer for all the rivets to help distribute the load on the fairing to hopefully eliminate any chance of cracking. I also had to put some rivets in the fairing on the wing skin to get fairing to lay flat. Overalll, it all turned out good and I like the way it looks. Will look even better once it is painted. Also note that the left wing in photo 1 has been cleaned as opposed to the wing in photo 2 which still shows all the oxidation and dirt from years of building. I did have to use heat gun to get fairings to fit up against fuselage but that was fairly easy to do. Other than doing some cleaning, the fuselage part of the plane is complete.
