Larrys Web Site
Date:  8-2-2018
Number of Hours:  4.00
Brief Description:  Interior Fuel lines
Routed all interior hoses to selector valve. Made bracket for each side from spare aluminum. Bracket was drilled out for two grommets which the fuel hoses from each tank passed thru. This bracket was attached to the L angles on the center spare used for the center stick option. This keeps the hoses near the floor and close to spar so they are away from your feet. All hoses ended up at the selector valve. This was a challenge to get all six hoses attached to the Andair selector valve. The valve is small in comparision to all the hoses it has connected to it. And because the center console is angled, this just made it harder to get hose fittings to thread onto valve. It took some time and some time with my head stuck under the instrument panel but I got them all connected. I will check them for leaks when I do the fuel flow test next week.
Right side from fuel tank
Left side from fuel tank
All hoses connected to selector valve
