After months of thinking about installing the wings, I have now officially completed them. All bolts are in place and have been torqued to the correct valves (120 to 145 inch-pounds for the main spar and 100 to 140 inch-pounds for the rear spar). As seen in the photos, I have torque sealed all the lower bolts and rear spar bolts but I still need to get the upper main spar bolts. I think the only way to do this is to stand on your head in the cockpit or I might try using my endoscope camera and marking them. I also wired the left and right fuel sensors to the EMS system and I began work on wiring in the nav/strobe lights.
