Left wing attached much like the right wing. However the hole alignment was not as good as the right wing. So I will need some assistance to get the permanent bolts in place. Photo 2 shows 9/32" steel tods inserted in holes. Once the holes are aligned, the rods will be replaced with the permanent bolts. I had to modify the L angle on this seat just like on the right seat.
