Larrys Web Site
Date:  5-3-2018
Number of Hours:  4.00
Brief Description:  Continue Flap Rod and Bearing Installation
The flap rod and bearings are somewhat of a challenge to install. You have to get on your knees and lean in thru the bottom hatch to do the work. Getting the bearings in the right place with little room to work at times was very frustrating. Especially when it came time to drill the bolt holes thru the bearings for mounting. As seen in the photos, everything is complete with the exception of the small L angle braces that need to be ritveted to the side skin. I plan on getting this completed during the next work session.
Pilots side bearing
Pilots side bearing
Passenger side bearing
