Had a friend come out today and assist with putting right wing into place. Had already cut sawhorses to proper height to allow for wing dehedral of 5.65. Had to trim top wing skin all the way across and bottom wing skin behind landing gear. Once skin was trimmed, wing slid all the way in and temporary bolts werre inserted. The bottom wing skin in fromt of the gear will need some work because the gap is too wide for the rubber trim piece to fit correctly. Also I need to contact Zenith and find out if it is ok for the rear spar attachment plate to fit behind the spar instead of in front of it.
Right wing inserted into center spar
Rear view of right wing with temporary bolts installed
