Brief Description: ELT installed and wiring clips installed
Got ELT back from being reprogrammed for NMEA mode instead of Aviation mode. Since I already had built and installed mounting tray for ELT, I went ahead and strapped ELT in place. Still need to fabricate the wiring harnss for it and connect it to the remote switch in the front panel. Did some more clean up on the wriing on the pilots side with some wiring clips I made to help hold wires in place. This will also help when interior if added.
