Larrys Web Site
Date:  1-22-2018
Brief Description:  Elevator trim
Since I had already completed wiring up the control stick, I decided I would connect it to the elevator trim before I finalize the wiring to make sure it works and moves the elevator trim tab the correct direction. I used a 9V DC battery for the test. The control stick trim button worked and the trim tab moved in the proper direction!! It will be a while before I can get the wings on and test the aileron trim. i am using the Ray Allen 305 control stick for the pilot and the 301 for the passenger side. Also did some more wring cleanup on the shelf. Unfortunately it looks like it will be March before I can get my ADS-B receiver so I am just leaving a spot for it on the shelf so when I get it all I will have to do is mount it on the shelf and connect the cables.
Control stick test wired to elevator trim
Test wiring running to elevator trim
