Brief Description: Mounted and wired ECU power panel
With wiring most completed for display and the radio, I moved over to the next hole and installed the ECU power panel. This panel is made by Composite Design and is based on the requires that UL Power has for its engine. It allows for isolating the electical system between the alternator and the battery in case of alternator problems. It also has the fuel pump selector switch and fuel pump on lights. Also has a light for low battery voltage and a check engine/sensor warning light. Wiring is shown in the first photo and was fairly simple. Just had to find the correct wires to fasten into place. The hole in the panel under the ECU power panel will the the radio panel and will have all the switches and circuit breakers for all the other instruments and misc components.
