Made cutouts in plastic panel cover and mounted the VHF radio and the Intercom Panel. Again not much to this mow that I had already temporarily positioned these in place. Bolted these to the panel and then hooked up cables shown in photo 2. The Rast Stack cabling makes this connection process go much faster. I stall have to connect these to the radio power panel but this is just two wires instead of many wires. The avionics shelf is getting crowded with wiring and I am trying to keep wiring as tidy as possible as I make each addiitional installation. Now all that is left to do is to install the UL Power control panel and radio power panel from Compostie Design and panel work will be complete with the exception of the ADS-B box which is on backorder.
