Larrys Web Site
Date:  11-29-2017
Number of Hours:  4.00
Brief Description:  Avionics work continues
Put all the instruments in panel and temporarily connected as much wiring and cables as was possible. Trying to figuire out the best way to route all the wires. Got ignition wires tie wrapped and positioned. Also spent time tie wrapping different types of wiring together. Put the 3M panel cover material on the panel. It is like contact paper only much thicker. Makes the panel look very neat. You can see the spots wherer I still need to make the cutouts in the paper in photo 2. Last photo is same as first one except it is from the right side of the plane.
Instrument shelf with many wires
Panel starting to fill up
Looking from passenger side
