Brief Description: Continue work on Avionics shelf
All holes drilled in shelf to mount remote avionics. Shelf mounted in aircraft (photo 1) with all avionics boxexs mounted except ADS-B box which is backordered and will not be available until after first of 2018. Second photo shows shelf with boxes mounted and wiring connected to ECU red box. Last photo shows transponder antenna installed.
