Larrys Web Site
Date:  11-17-2017
Number of Hours:  4.00
Brief Description:  Continue work on Avionics shelf
All holes drilled in shelf to mount remote avionics. Shelf mounted in aircraft (photo 1) with all avionics boxexs mounted except ADS-B box which is backordered and will not be available until after first of 2018. Second photo shows shelf with boxes mounted and wiring connected to ECU red box. Last photo shows transponder antenna installed.
Instrument panel and shelf
Shelf with boxes installed
Bottom view of transponder antenna
