Larrys Web Site
Date:  11-13-2017
Brief Description:  GPS Wire
Attached plastic sleeve to GPS wiring and routed wire thru firewall. Drilled hole in center console for ignition switch. Switch installed to see best way to route wiring.
Wire run thru firewall
Ignition switch test fit
