Larrys Web Site
Date:  9-25-2017
Number of Hours:  4.00
Brief Description:  Installed Oil dip stick door in cowling
After attending the Open Hangar days and seeing what everone else had done with oil dip stick door, I decided to take a different approach. Everyone I talked to about thiis said it was very difficult to get to dip stick with the way the door opening was installed. So I decided to make sure the hole I cut for the opening was centered on the dip stick so it would be easy to get my hands on it. With that in mind, I also decided since the dip stick was right in the center of the bubble seam on the cowling, I decided to use the fiberglass piece that I cut out to make the hole for the door. This way I did not have to make compound bends ti the metal door that was provided in the FWF kit. I think it will worik fine. I plan to use 2 dzeus fasteners to make sure the door stays shut. In the last picture you can see the dip stick at center left of the picture. I now feel much better about this knowing I can access the dip stick with ease.
Hole cut in cowling
Hole cut in cowling
Used cutout for door
Yes that is the dip stick in the left center of the opeining!!!!!
