After studing the throttle installation instructions (NOT). There are no instructions for throttle installation. So I decide to try and put this all together to see how it fits. There are two cap head bolts that hold brackets in place. The only problem is once you get both brackets with cap bolts installed there is no way to get cable into brackets. I'm sure I am mission a key step somewhere along the way and someone thought this was so simple that there was no need to instructions. I did manage to get it all put togeher but I had to leave the upper bolt out to make it work. Now I will try to see if there is a way to put it together and get the top bolt installed as well. Still deciding on where exactly to put the throttle in panel so this part will have to wait until more info is obtained on avionics locations.
