Larrys Web Site
Date:  8-25-2017
Brief Description:  Brake fluid added to Master cylinders
Adde Shell 31 (83282D) brake fluid to brake system. Connected squirt can filled with brake fluid to bleed valves on brake assembly. Pumped fluid into left and right sides. LInes that were empty and white are now full and red.
Brake line filled
Brake line filled
Brake lines under fuselage filled
Brake lines in cockpit filled
