Larrys Web Site
Date:  8-14-2017
Brief Description:  Ignition wire to starter
Ran wire from ignition switch to starter. Used #18 sheilded wire and ran wire in protective wire loom. Wire runs thru grommet hole on right side of firewall. Ignition switch is completely wired and just need to drill hole in instrument panel for mounting. I will waiting to drill hole until I get all the instruments located in the panel and decide where I will install ignition switch.
Starter Wiring
Starter Wiring
Wire thru firewall
Wire thru firewall
Wire Routing
Wire Routing
