Worked on installing shunt for amp meter. Mounted shunt to firewall with AN4 bolts and nuts. Then I ran #8 wire from master solenoid to high (top) connection on shunt. Then ran #8 wire from llow side of shunt(bottom) thru grommet in firewall. The end of this wire will connect to the power panel once it is installed. Mounting the shunt in this position allows for monitoring the amp load on the power panel. Instructions call for 1amp fuses in the wries going back to the Dynon Skyview EFIS. Photo 2 shows fuse holders installed and ready for mounting once power panel is installed.
