Finally got order in from ACS which had the 2x2 sheet of aluminum I needed to make the avionics shelf. Added two more L angles to the two existing angles which were installed for the center console. Drilled and clecoed shelf in place. Still need to drill and cleco the center console L angles. Also cut hole in center rear part of shelf for a wiring passage way.
