Did not have much time today to devote to airplane so when I did I picked to simple things to do. First I added a diode on the starter solienoid from the bolt for the ignition switch wire and the other end of the diode to grouind. Thsi wire came with the ignition switch in the FWF kit. Next I decided to try out some of the 1/4" wiring loom I purchased. It make protecting and securing the alternator wires very easy. Actually the hardest part was getting the 3 wires in the loom. Once I got them in, then I tie wrapped the loom to the enginer mount and the mounting plate holding the coil. Since this worked so well, I have ordered two more pieces of 1/2" and 1" loom. I will use these on coil wires and sensor wiring going back to cockpit. Ordered needed electrical supplies from ACS and now waiting for parts to arrive.
