Went to hangar today to finish cleaning out trash and other items. Sprayed for bugs inside and out. Since I spent time at hangar, I did not have much time to work on canopy. I did get the canopy trimmed to fit and drilled 1/8" holes thru canopy into front rear tube. Next step will be to remove the canopy and drill ouit side rails to 1/8" and then reattach canopy and drill canopy to side rails. I will be using screws instead of rivets in the tubes and side riails so I will have to enlarge the holes in the canopy to 5/16".
