Larrys Web Site
Date:  4-12-2017
Number of Hours:  3.00
Manual Reference:  6C
Brief Description:  Front Canopy fitting
Front canopy positioned on centerline to get cut marks established. Cut rear of front canopy to align it with tube frame. Put canopy back on and taped it down. Also put on weatherstrip along front edge to get proper height for sides. Will need to trim front edge in order to get sides down to bottom of side frame rails. Once everything is aligned, I will drill out with plasitic bit (1/8") and then prepare canopy for screws. Talked to Katlin at Zenith today and UL Power engine shouild be shipping in a couple of weeks. I woiuld like to be finished with canopy by the time the engine arrives. I believe this is doable.
Front canopy marked for rear cutting
Looking at canopy from left rear
Front view with weatherstrip installed
