Decided to work on setting rudder cable tension. Slowly adjusted rudder turnbuckles until rudder was centered and cable tension was 22# +/- 5#. I used a Burrroughs Cable tension gage to check cable tension. The tension in these pictures is reading about 27#s. I figured the cable will stretch some initially. I will check it again in a couple of weeks. Then I will safety wire the turnbuckles.
