Brief Description: Install gas springs and brackets
Measured back from side frame pivot bolt 290mm to where stud on gas spring bracket is to be installed. Positioned brackets and drilled 8 A5 holes. Once these were drulled, I removed brackets and countersunk all eight holes. Clecoed brackets in place and positioned gas springs on brackets to see how it all fits. Everything looked good. I measured the angle on each of the side frames as shown in the pictures. They were within 1 degree of each other. I think that will be close enough. The actual angle was 65 degrees.
