Brief Description: Connect and Safety wire calipers
Safety wired and connected calipers to the gundrilled holes at bottom of gear. Also installed 90 degree fittings in gundrilled holes on rear of spring gear shown in photo 3. Brake line tubing will be routed in the center channel on the bottom of the aircraft. My plan is to bring brake line back into cabin just forward of the center console where the parking brake will be insalled. From there it is just a short distance to the master cylinders.
