Completed work on steps today. Riveted steps and fairings. Also cut and fitted step bottom cover to fuselage. Deburred, cleaned and applied corrosion protection as well as priming. Riveted bottom cover in place. My steel bungee arrived today so I spent some time cleaning it up and primed and painted the side brackets and the spring. Once I get another nose gear from Zenith(hopefully tomorrow) I will continue work on getting nose wheel finished.
