Brief Description: Reassemble bottom skin for riveting
Got rear ribs riveted to rear channel and front spar. Also connected cables to aileron bellcrank. Drilled holes and installed grommets in rear ribs for nav/strobe light wiring. Added L angle bracing to underside of bottom skin. Nose ribs also were riveted in place. Next will be to cleco bottom skin for riveting.
