Continued work on disassembly of right wing. Removed rear channel and started removing rear ribs. I deburr items as I remove them. Once deburred, they go into the deburr pile which I hope to to finish tomorrow. Once deburred, I will apply corrosion protection and then start process of putting it all back together. I have also received the parts list from Zenith for the finishing kit which I need to review and selec those items I have already ordered so I can remove them from the list. I will not be ordering the spring gear and wheels/tires/brakes from Zenith. I will be ordering these from Grove. Zenith supplies their own spring gear which weighs 46 pounds and the Grove gear weights 32 pounds. I know it will cost about twice what the Zenith gear wouild cost, but I am trying to save weight wherever I can and 14 pounds is a big chunk. I also like the idea of having the gear gun drilled to reduce the exposure of the brake lines.
