Had some minor problems with right nose skin. I could not get the overlap I wanted from the nose skin over the top rear skin. I had no problems with this on the left wing and I thought I did both wings the same. Called Roger at Zenith to see if the overlap had to be 10mm. He said a minimum of 6 or 7 would work which is good because mine measured 7mm. So I proceeded to drill nose skin.
