Larrys Web Site
650
6W
Fuel sender hole cut in tank
Cut hole in left fuel tank for fuel sender. Used the smaller hole method which will give more gasket sealing surface to work with. Washed tank out and let it dry. Nest will be to install all fittings and parts and do a leak check.
Left tank with hole for fuel sender
650 Home
1414
496
Gear
312
