Larrys Web Site
Date:  3-15-2016
Number of Hours:  5.00
Manual Reference:  6W
Brief Description:  Wing Ready for Disassembly
Left wing has all holes drilled out to final size. Drilled hole in rear channel for aileron trim wire to feed into main wing. Also cut out hole in rear channel for aileron balance arm. Only thing left is to put navigation lights in wingtip, mount pitot tube, install fuel tank permanently and run fuel lines, run wires for fuel sender and run ruel return line. However, since all of this is interior to the wing, I decided to disassemble wing for deburring and corrosion protection. I will reassemble wing and rivet skeleton and bottom skin and then put the rest of the interior pieces together before installing top skin for final riveting. Pictures below show rear channel apart and drying after corrosion protection was appied. Will rivit rear channel together tomorrow. Also still need to get additional connections welded to fuel tanks for the Belite fuel sensor and for the fuel return line.
Wing skins removed
Wing skins removed
Rear channel disassembled
Rear channel deburred and corrosion protection applied
