Brief Description: Top Leading Edge skin Installation
Had a friend come over and assist with moving left wing to another table and turning it top side up so I could attach top LE skin to spar. It took some time to get everything level again and get the straps in place. Once I had the skin in place and strapped, I checked the edge of the LE skin that goes on the spar to make sure I had enough overhang to drill the pilot holes thru the top rear skin and have at least 10mm edge distance on the LE skin. Once again I was amazed that I had exactly 10mm of edge distance. I love it when things work out like they are desiigned. Drilled all the holes in the spar the #40 pilot holes. Hopefully tomorrow I will have time to drill the top of the nose ribs.
Inboard side of wing with LE skin strapped and spar clecoed
