Started today by gettin wing turned over with bottom side up. This was easier than I thought it would be and I managed to do it by myself. However it would have been much easier with 2 people. Once I got the wing turned over, I put the wooden supports I made under the main spar and the rear channel. I think it was just luck but when I put the level on it, both spars were level and the main spar was at 81 degrees! That will never hapen again. I didnt believe it at first so I recalibrated the level twice just to make sure. Got all the holes drilled but I ran short on 1/8" clecos. Will review work for nose ribs tomorrrow.
