Brief Description: Rear spar Channel and Left Wing Work
I completed work on the rear spar channels and decided to start on one of the wings. I laid out ribs and drilled ond clecoed to left main spar. Ribs required some tinkering to get front of rib flange to fit on spar. They show how to do this in the photo manual but it looks much easier in the photos than it turns out to be. Also no where does it say how you are supposed to get rear rib #1 drilled to the spar with the upgraded wing root doubler already installed. I guess I will have have to remove the wing root doubler to attach the rib and then reinstall the doubler. I will call Zenith tomorrow to confirm this is correct.
