Larrys Web Site
650
6T-6
Elevator trim wired
Soldered Belton 5-wire cable to elevator trim motor. Pulled cable thru rubber grommet on forward side of elevator. Connected supplied toggle switch and position indicator to make sure wiring was good and everything worked correctly. It all works!!!
Elevator trim motor wired
Cable coming out on forward side
Everything actually works!!!
650 Home
1414
496
Gear
312
