Carefully gluing each member and fitting into jig blocks and using cam blocks to press and secure the lower longerons to the members applying pressure on the rest of the assemblies.
Look, I'm building a plane
They said I should have a few pictures of me actually building!
Test pieces - these will be destroyed to check the glue batch. This is done during each glue session
