Brief Description: Assembled rudder and buttoning HS
Assembled rudder skeleton, now waiting for inspection before I rivet the skins and trailing edge. started to rivet the skin on korizontal stabiliser, I had to make a repair on hs 707 when matched drilled it moved and drilled beside the prepunced hole. to repair I used a piece of aluminium from the stiffener material to ensure proper grip for the rivet.
assembled waiting for inspection before buttonig skin
