Kupe's Zodiac 650B
Date:  6-28-2014
Number of Hours:  2.50
Manual Reference:  6-C-3
Brief Description:  Forward Rear Canopy Frame Fitting
Today was spent sizing, cutting, resizing, bending, resizing, and attaching the forward rear canopy frame. I started by temporarily reinstalling the baggage floor to make sure I wasn't inadvertently attaching the canopy to a fuselage that wasn't quite aligned correctly. Not to worry, everything fit back together like a glove.
Next, I permanently attached the aft rear frame to the top longeron via a small gusset. This ensures the aft frame remains in its precise position while I manuever the forward frame around on the movable side frames.
Then I measured the forward rear frame to determine where to cut off the ends and made about 4 trips between the airplane and workbench getting the length and curvature just right - to where it mirrors the aft rear frame.
Lastly, I attached the forward rear frame to the side rails via a pair of .09 aluminum brackets that also cleverly align the forward frame to the rear frame while closing the canopy. As best I can tell, everything is good to go.
Right side aft rear frame gusset attached to the upper longeron.The tape is holding 5mm spacers.
Both rear frames after fitting and initial attachment of the forward one to the side frames.
Canopy frame propped partially open to get a sense of how it will open and close.
