The left side panel nut plate installation was the same as the right side. Eleven more nut plates to attached the center console left side panel with screws.
A look at the inside of the left panel after installing the nut plates.
Looking aft and down from the firewall - upper rails and floor bracket nut plates.
Left side panel loosely screwed into place for test fitting.
