Brief Description: Riveting the Forward Fuselage 6 (Seats)
Finished riveting the left forward fuselage skin. The only skin rivets not completed at this point are those in the rivet line connecting the forward fuselage side skins with their respective aft fuselage side skins.
Installed and riveted the front seat panels into place which are attached to the center wing spar, their respective side skins, and the gear channel. Next I riveted the seat bottoms which act like a sling between the front seat panel and the rear seat panel. Finally, I riveted in the two arm rest sides which also have the inboard seatbelt attach point integral to them. The sitting area is solid as a rock now.
The seats, from the firewall (front) all riveted in place.
The seats, viewed from the right side. The armrest side walls are also in place.
