Drilled holes in the leading edge skin to accommodate the fuel tank vent tube and the fuel tank drain valve. It's nice to see the tank sitting in place.
The fuel vent sticking through the bottom of the leading edge.
The fuel drain fitting sticking through the bottom of the leading edge.
The left wing long-range fuel tank in place. The new return line fitting is visible (red cap).
